palio diagnostika pomoc
ambroz666
Příspěvek od ambroz666 »
ahoj mam fiat palio weekend 1.2 54kw verzia 75 riadiaca jednotka je IAW18FB4 magneti mareli konektor na pripojenie je v motori pri riadiacej ma tri vývody K linku , L linku , a N .nevieš aký softvér a cez aké rozhranie -schému zapojenia sa dá urobiť diagnostika stačí iba čítanie porúch poprípade mazanie chýb ak sa dá tak odpíš ďakujem ambroz666@gmail.com
milanluko
Re: palio diagnostika pomoc
Příspěvek od milanluko »
nasiel som toto, ale je to EN:
Making an OBD to Fiat connector:
you obviously havent seen the millions of threads i've written about using a few bits of wire to get a 3 pin connector on your car working with an obd connector on a reader. its very easy, and free!
you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to code reader.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
you need to remember that there are several 3 pin connectors. the main one is on the front of the fuse box cover in the engine bay.
you could very easily wire a obd connector permanently onto your car (only 4 wires), but you'd need to do at least 3 connectors to cover all modules since there are at least 3 connectors on your car and you cant wire them all into one obd connector safely.
personally i think its better to use 4 lengths of wire and the fiat 3 pin connectors.
kabel kupis tuto:
http://www.viaken.pl/sklep.php?lang=en&prodid=14" onclick="window.open(this.href);return false;
http://ucables.com/ref/CO-FIAT" onclick="window.open(this.href);return false;
Doktor.cz
Příspěvek od Doktor.cz »
Z toho nejsu uplně chytrý.
A nedá se kouopit kabel na jiné rozhraní? Na notebooku je serióvý port už historií...
Fiat Punto Sporting 1.2 16V r.v. 1997
Patrik
Příspěvek od Patrik »
Sehnat kabel se dá kdekoliv nebo ubastlit, horší je sehnat na italy soft, zejména pokud veezmete v úvahu že daný soft si rozumí jen s daným typem kabelu ...
Doporučuji kabel založený na ELM čipu, ten by měl se ScanMasterem (sw) fungovat.
lolo26
Příspěvek od lolo26 »
ten smejd ELM nefunguje
UNISCAN áno
Ľudkovia kto by chcel tester na staršie autička poskladam.aj soft k tomu čiastočne v češtine
cena 70 Eur
popis UNISCANU:
Diagnostika pre europske autá do roku 2000 nutné mať na pc 2x com port.
Podpora značiek Audi , Alfa Romeo , BMW , Citroen , Fiat , Ford , Lancia , Mercedes , Mitsubishi , Opel , Peugeot , Rover , Seat , Skoda , VW , Volvo.
Podporované modely:
Europské vozidlá vyrobené do roku 2000, Audi, Alfa Romeo, BMW, Citroen, Fiat, Ford, Lancia, Mercedes, Mitsubichi, Opel, Peugot, Renault, Rover, Seat, Škoda, Volvo, VW.
OPEL do 1999 - diagnostika motora, imobilizéra, abs, airbagu
FORD do 1995 - diagnostika motora
Renault do 1999 - diagnostika motora
BMW do 1999 - diagnostika motora
MERCEDES do 1999 - diagnostika motora, imobilizéra, abs, airbagu
Fiat, Alfa Romeo, Lancia do 1999 - diagnostika motora, imobilizéra, abs, airbagu
Program umožňuje:
- načítanie chybových kódov z pamäte riadiacej jednotky, zobrazenie textového popisu chyby
- mazanie uložených chybových kódov
- monitorovanie prevádzkových veličín v reálnom čase
- testy akčných členov
- informácie o diagnostickej zásuvke a jej umiestení
nevyhody: pracuje len pod DOS-om
PC musí mať 2 COM porty
USB-RS232 nepodporuje
pošlem na dobierku
kto chce nech mailuje fiat.servis@zoznam.sk
