palio diagnostika pomoc
ahoj mam fiat  palio weekend 1.2 54kw  verzia 75  riadiaca jednotka je IAW18FB4 magneti mareli  konektor na pripojenie je v motori pri riadiacej ma tri vývody K linku , L linku , a N .nevieš aký softvér a cez aké rozhranie -schému zapojenia sa dá urobiť diagnostika stačí iba čítanie porúch poprípade mazanie chýb ak sa dá tak odpíš ďakujem ambroz666@gmail.com
Re: palio diagnostika pomoc
nasiel som toto, ale je to EN:
Making an OBD to Fiat connector:
you obviously havent seen the millions of threads i've written about using a few bits of wire to get a 3 pin connector on your car working with an obd connector on a reader. its very easy, and free!
you need 4 lengths of wire. use 3 lengths of wire to connect the 3 pin connector to the obd connector. also use 1 length of wire for power to code reader.
on the 16 pin obd2 connector use the following pins
4- chassis ground (connect to ground on 3 pin connector, or any good chassis earth)
5- signal ground (connect to black wire pin on 3 pin connector)
7- k line (connect to white wire pin on 3 pin connector)
16- 12vDC (connect to battery positive terminal)
you need to remember that there are several 3 pin connectors. the main one is on the front of the fuse box cover in the engine bay.
you could very easily wire a obd connector permanently onto your car (only 4 wires), but you'd need to do at least 3 connectors to cover all modules since there are at least 3 connectors on your car and you cant wire them all into one obd connector safely.
personally i think its better to use 4 lengths of wire and the fiat 3 pin connectors.
kabel kupis tuto:
http://www.viaken.pl/sklep.php?lang=en&prodid=14" onclick="window.open(this.href);return false;
http://ucables.com/ref/CO-FIAT" onclick="window.open(this.href);return false;
kabel kupis tuto:
Z toho nejsu uplně chytrý.
A nedá se kouopit kabel na jiné rozhraní? Na notebooku je serióvý port už historií...
Fiat Punto Sporting 1.2 16V r.v. 1997
Sehnat kabel se dá kdekoliv nebo ubastlit, horší je sehnat na italy soft, zejména pokud veezmete v úvahu že daný soft si rozumí jen s daným typem kabelu ...
Doporučuji kabel založený na ELM čipu, ten by měl se ScanMasterem (sw) fungovat.
ten smejd ELM nefunguje
UNISCAN áno
Ľudkovia kto by chcel tester na staršie autička poskladam.aj soft k tomu čiastočne v češtine
cena 70 Eur
popis UNISCANU:
Diagnostika pre europske autá do roku 2000 nutné mať na pc 2x com port.
Podpora značiek Audi , Alfa Romeo , BMW , Citroen , Fiat , Ford , Lancia , Mercedes , Mitsubishi , Opel , Peugeot , Rover , Seat , Skoda , VW , Volvo.
Podporované modely:
Europské vozidlá vyrobené do roku 2000, Audi, Alfa Romeo, BMW, Citroen, Fiat, Ford, Lancia, Mercedes, Mitsubichi, Opel, Peugot, Renault, Rover, Seat, Škoda, Volvo, VW.
OPEL do 1999 - diagnostika motora, imobilizéra, abs, airbagu
FORD do 1995 - diagnostika motora
Renault do 1999 - diagnostika motora
BMW do 1999 - diagnostika motora
MERCEDES do 1999 - diagnostika motora, imobilizéra, abs, airbagu
Fiat, Alfa Romeo, Lancia do 1999 - diagnostika motora, imobilizéra, abs, airbagu
Program umožňuje:
- načítanie chybových kódov z pamäte riadiacej jednotky, zobrazenie textového popisu chyby
- mazanie uložených chybových kódov
- monitorovanie prevádzkových veličín v reálnom čase
- testy akčných členov
- informácie o diagnostickej zásuvke a jej umiestení
nevyhody: pracuje len pod DOS-om
PC musí mať 2 COM porty
USB-RS232 nepodporuje
pošlem na dobierku
kto chce nech mailuje fiat.servis@zoznam.sk
						UNISCAN áno
cena 70 Eur
popis UNISCANU:
Podporované modely:
Program umožňuje:
pošlem na dobierku
